plz help me --blue screen problem
VIJAYMY4RDS
hi all
i bought a new lap top. When ever i tried to safely remove my external hard disk a blue screen appears and it is restarting the system and at the booting screen it is showing me that" system was not shutdown properly ".etc
plz help me out
thanks in advance
I have analysed your Minidumps:
IRQL_NOT_LESS_OR_EQUAL
STOP: 0x0000000a
Drivers referenced:
  • ntoskrnl.exe x 8
  • ndisuio.sys x 1
Usual Cause: Device Driver
Make sure ALL your drivers are up to date. In particular, make sure your external hard disk drivers are up to date. Make sure Windows is fully up to date. Download and run the free Malwarebytes Anti-Malware. What exact external hard disk driver are you using?
Also, these drivers are very old and need to be updated:
2006:
  1. secdrv.SYS
  2. peauth.sys
  3. Null.sys
  4. Swenum.sys
2007:
  1. spldr.sys
  2. spsys.sys
  3. PxHlpa64.sys
  4. HDAudBus.sys
Good luck,
Richard
    Dell XPS 420
    Stock Dell 0TP406
    4 gb (DDR2 800) 400MHz
    1600 x 1200 and 1280 x 1204
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
