Help! Memory_management bsod
chaosrealm93
Power User
i was reinstalling everything after a format and this BSOD randomly popped on my screen. can someone help me decode this?
*i could not find the last two files for some reason. maybe it had to do with it being in the "temp" folder
    AMD Phenom ii 940 - 3.60GHz
    ASUS M3A79-T Deluxe
    Kingston HyperX 2x2GB 1066MHz 4096MB
    4870 1GB
    N/A
    Viewsonix VX2240w
    1680 x 1050
    Western Digital Caviar Black 1TB 7200rpm
    Corsair AX850
    Coolermaster HAF 932
    Scythe Mugen 2 rev.b
    Logitech G500
    Das Keyboard Silent Professional
    iunno.
STOP: 0x0000001a
MEMORY_MANAGEMENT
Run memtest86+ to check your RAM. Were you doing anything particularly stenuous, as this BSOD can be caused by not enough power to the system. This BSOD is usually caused by hardware, but have a look at these two sites:
Troubleshooting Windows STOP Messages
If this has only just started after a clean install, I would also make sure all your drivers and Quicktime are up to date.
Richard
    Dell XPS 420
    Stock Dell 0TP406
    4 gb (DDR2 800) 400MHz
    1600 x 1200 and 1280 x 1204
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
Hello chaosrealm93,
Can you upload the minidump file with your next post, and we will take a look at it, thanks.
C > Windows > Minidump, zip them up and upload them, you may need to save them to your desktop first.
    Self Build
    Asus P5Q Premium
    2 x ASUS EAH 4870 X 2 (Quad)
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
Hello chaosrealm93,
Stoneys-nutz: If you re-name the text file chaosrealm93 uploaded in his previous post to .dmp, you can analyse it normally. I do not know why chaosrealm93 renamed it to .txt, probably to get past the problem of not allowed to upload .dmp files. I have uploaded a copy of the file renamed to .dmp in a zip archive.
Richard
    Dell XPS 420
    Stock Dell 0TP406
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
Hello chaosrealm93,
Richard
Good work, i was waiting to see who would spot that first. :o
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
Do you have the latest chipset drivers installed ?.
And why did you format, was it because of BSOD errors ?.
Try removing all but one stick of ram and trying it, swap sticks and try again.
It could be a driver, but after a format and a fresh install ?, i would eliminate the ram first.
Hope this helps, good luck and post your results.
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
no, i have the latest drivers for all my hardware. i ran 1 loop of memtest86+ for the 8GB of RAM and they came back successful.
btw, is memtest86+ v4.00 the newest version? i see a lot of forum posts saying 2.11 is the newest
    ASUS M3A79-T Deluxe
    4870 1GB
    N/A
    Viewsonix VX2240w
    1680 x 1050
    Corsair AX850
    Logitech G500
    iunno.
You need to run Memtest a lot longer, maybe over night to get proper results.
I would remove a stick of ram and try the system, until you have gone past the point where you would normally get a BSOD, then try another, i have found its the best way to eliminate ram from a problem system.
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
so is v4.00 the newest?
    ASUS M3A79-T Deluxe
    4870 1GB
    N/A
    Viewsonix VX2240w
    1680 x 1050
    Corsair AX850
    Logitech G500
    iunno.
I have never used it, so i dont know, try to Google it, or go to their site.
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
