Help - Blue Screen problem
belewski
I have a packard bell easy note laptop just changded the ram from 512 to 2 x1g no problem. Starts up fine when i add my vodafone inteernet stick with in mins a blue screen comes up with no errors messages and reboots. Ive turned atuo restart off and it just stays on blue screen. comp is Intel(R) celeron(R) M CPU 410 @1.46GHz
If any one can help fix this thanks
Problem signature:
Problem Event Name: BlueScreen
OS Version: 6.0.6000.2.0.0.768.2
Locale ID: 2057
Additional information about the problem:
BCCode: 50
BCP1: 82926438
BCP2: 00000000
BCP3: 821EB870
BCP4: 00000000
OS Version: 6_0_6000
Service Pack: 0_0
Product: 768_1
Files that help describe the problem:
C:\Windows\Minidump\Mini092809-04.dmp
C:\Users\Emily\AppData\Local\Temp\WER-86109-0.sysdata.xml
C:\Users\Emily\AppData\Local\Temp\WER76D1.tmp.version.txt
Read our privacy statement:
http://go.microsoft.com/fwlink/?linkid=50163&clcid=0x0409
    2gram 60hd
Problem signature:
Locale ID: 2057
BCCode: 50
BCP1: 82926438
BCP2: 00000000
BCP3: 821EB870
BCP4: 00000000
Service Pack: 0_0
Product: 768_1
Microsoft Online Crash Analysis
belewski
go into c:\windows\minidump, zip the dump file (*.dmp) and upload it to us using the attachment icon (shaped like a paperclip)
thanks
Ken
    Dell Inspiron E 1405
    [email protected]
    4 gigs
    integrated intel 945
    integrated
    300 gig internal
    10 down 1.5 up
Hi wont alow me copy files altough im the only user as addminstrated.
I did remove mozilli fire fox this seems to have solved the problem but if you could still advise me on how to get the files coped and uploaded so you could take a look.
Many Thanks
Martin
    2gram 60hd
If you reboot to safe mode, you should be able to access your dump files.
    AMD AM2 6000+
    Nvidia M2N-E SLI
    GeForce 7600GT
    WD
    Cooler Master
    Three fans
    Dell Optical
    Dell Quietkey
    10 MBPS
What happens if you reinstall your old memory and remove the Vodaphone Internet Stick?
    AMD AM2 6000+
    Nvidia M2N-E SLI
    GeForce 7600GT
    WD
    Cooler Master
    Three fans
    Dell Optical
    Dell Quietkey
    10 MBPS
kd> !analyze -v
* Bugcheck Analysis *
PAGE_FAULT_IN_NONPAGED_AREA (50)
Invalid system memory was referenced. This cannot be protected by try-except,
it must be protected by a Probe. Typically the address is just plain bad or it
is pointing at freed memory.
Arguments:
Arg1: 82926438, memory referenced.
Arg2: 00000000, value 0 = read operation, 1 = write operation.
Arg3: 821eb870, If non-zero, the instruction address which referenced the bad memory
address.
Arg4: 00000000, (reserved)
Debugging Details:
READ_ADDRESS: GetPointerFromAddress: unable to read from 821275a0
Unable to read MiSystemVaType memory at 821086a0
82926438
FAULTING_IP:
nt!CmpCallCallBacks+17b
821eb870 8b0d38641282 mov ecx,dword ptr [nt!CallbackListLock (82126438)]
MM_INTERNAL_CODE: 0
CUSTOMER_CRASH_COUNT: 3
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
BUGCHECK_STR: 0x50
PROCESS_NAME: lsass.exe
CURRENT_IRQL: 0
TRAP_FRAME: 930c3b4c -- (.trap 0xffffffff930c3b4c)
ErrCode = 00000000
eax=00000000 ebx=89c40bc8 ecx=858da1b8 edx=85512b40 esi=85512b40 edi=9dfa4380
eip=821eb870 esp=930c3bc0 ebp=930c3c30 iopl=0 nv up ei pl zr na pe nc
cs=0008 ss=0010 ds=0023 es=0023 fs=0030 gs=0000 efl=00010246
nt!CmpCallCallBacks+0x17b:
821eb870 8b0d38641282 mov ecx,dword ptr [nt!CallbackListLock (82126438)] ds:0023:82126438=????????
Resetting default scope
LAST_CONTROL_TRANSFER: from 82049184 to 82057325
STACK_TEXT:
930c3b34 82049184 00000000 82926438 00000000 nt!MmAccessFault+0x14b
930c3b34 821eb870 00000000 82926438 00000000 nt!KiTrap0E+0xdc
930c3c30 821eea6f 0000000e 930c3c78 00000001 nt!CmpCallCallBacks+0x17b
930c3c8c 821dc444 a228b888 8239b078 a228b870 nt!CmpDeleteKeyObject+0x69
930c3ca8 8206a381 a228b888 00000000 858da180 nt!ObpRemoveObjectRoutine+0x100
930c3cd0 821dc71d 93c230a8 858da180 000006b8 nt!ObfDereferenceObject+0xa1
930c3d14 821dc7a0 93c230a8 93c25d70 8574d020 nt!ObpCloseHandleTableEntry+0x254
930c3d44 821dc878 8574d020 858da101 858da101 nt!ObpCloseHandle+0x73
930c3d58 8204607a 000006b8 0125f6b4 77dc0f34 nt!NtClose+0x20
930c3d58 77dc0f34 000006b8 0125f6b4 77dc0f34 nt!KiFastCallEntry+0x12a
WARNING: Frame IP not in any known module. Following frames may be wrong.
0125f6b4 00000000 00000000 00000000 00000000 0x77dc0f34
STACK_COMMAND: kb
FOLLOWUP_IP:
SYMBOL_STACK_INDEX: 2
SYMBOL_NAME: nt!CmpCallCallBacks+17b
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: nt
IMAGE_NAME: ntkrnlmp.exe
DEBUG_FLR_IMAGE_TIMESTAMP: 49ac8ca5
FAILURE_BUCKET_ID: 0x50_nt!CmpCallCallBacks+17b
Followup: MachineOwner
Module:
kd> lmvm nt
start end module name
82000000 82395000 nt (pdb symbols) c:\symbolfiles\ntkrnlmp.pdb\0A1B87242A104CE5908C9D187C0282492\ntkrnlmp.pdb
Loaded symbol image file: ntkrnlmp.exe
Mapped memory image file: C:\symbolfiles\ntoskrnl.exe\49AC8CA5395000\ntoskrnl.exe
Image path: ntkrnlmp.exe
Image name: ntkrnlmp.exe
Timestamp: Tue Mar 03 12:49:25 2009 (49AC8CA5)
CheckSum: 00351ACA
ImageSize: 00395000
File version: 6.0.6000.16830
Product version: 6.0.6000.16830
File flags: 0 (Mask 3F)
File OS: 40004 NT Win32
File type: 1.0 App
File date: 00000000.00000000
Translations: 0409.04b0
CompanyName: Microsoft Corporation
ProductName: Microsoft® Windows® Operating System
InternalName: ntkrnlmp.exe
OriginalFilename: ntkrnlmp.exe
ProductVersion: 6.0.6000.16830
FileVersion: 6.0.6000.16830 (vista_gdr.090302-1506)
FileDescription: NT Kernel & System
LegalCopyright: © Microsoft Corporation. All rights reserved.
You have no Service Pack. Install SP1 and then SP2 and then we'll see what to do next. Also, update your drivers. This is a critical system crash related to memory too. Take out one stick. Are they matched modules?
    Sony Vaio Z46GDU
    6GB DDR3 1066MHz SDRAM
    13.1" WXGA True Colour Tough
    1600x900
    320GB SATA 7200RPM
    1MB/s
hi i have just 1 of the new 1g in at the moment and all is fine but i want to add the other 1g as my sidebar ram says its using 67% in idle .
    2gram 60hd
Is the RAM a matched set? Can you install both service packs?
    Sony Vaio Z46GDU
    1600x900
    320GB SATA 7200RPM
    1MB/s
    Sony Vaio Z46GDU
    1600x900
    320GB SATA 7200RPM
    1MB/s
Belewski,
After installing the SPs, I hope that does the trick. But if it doesn't, please reinstall your old memory and remove the Vodaphone Internet Stick and tell us if that returns your stability!!!
    AMD AM2 6000+
    Nvidia M2N-E SLI
    GeForce 7600GT
    WD
    Cooler Master
    Three fans
    Dell Optical
    Dell Quietkey
    10 MBPS
    2gram 60hd
Belewski,
...please reinstall your old memory and remove the Vodaphone Internet Stick and tell us if that returns your stability!!!
    AMD AM2 6000+
    Nvidia M2N-E SLI
    GeForce 7600GT
    WD
    Cooler Master
    Three fans
    Dell Optical
    Dell Quietkey
    10 MBPS
hi i have 1 1g new memory in and all is fine download sp1 comp seems slower now put second 1g memory in and blue screen comes up when tryin to do more than i thing have removed second 1g memory.Can my comp not handle 2g of ram.
    2gram 60hd
sorry 4got 2 mention im conecting to the net using the built in wireless noproblems and the same with the vodafone stick
    2gram 60hd
What is the specific Model of your Packard Bell Easynote?
    AMD AM2 6000+
    Nvidia M2N-E SLI
    GeForce 7600GT
    WD
    Cooler Master
    Three fans
    Dell Optical
    Dell Quietkey
    10 MBPS
