System Restore Blue Screen Help
penfan
Banned
Today while doing a system restore i got some kind of blue screen. system restore was at the point where it says configuring your system and stuff and the back is the same as the windows welcome screen. But then all of a sudden it went to some kind of blue screen. I barely got to read it before the computer restarted and once I got to the desktop I got a message saying windows has recovered from an unexpected shutdown. How serious is this? Please help because ive only had this computer for alittle over a year and I've just about had it with it.
Can you safe boot? (F8 repeatedly while rebooting). If so go into c:\windows\minidump, zip the dump file and upload it to us to look at. If its not in minidump do a search for *.dmp.
Ken
    Dell Inspiron E 1405
    [email protected]
    4 gigs
    integrated intel 945
    integrated
    300 gig internal
    10 down 1.5 up
honestly im not really sure how to do that. im afraid i'll just mess my computer up more. its just gone out of warranty over a month ago. this computer has always been problems since i got it. the first day i had to reinstall vista and then it kept restarting itself and found out my hard drive was failing only after months of owning it then the second hard drive would freeze go to a blue screen they when it tried rebooting itself it said it couldnt detect a hard drive. so i got a third hard drive from dell which is the one im using now. i wish i could return it or get my money back and just buy a new computer.
Reboot your pc, and keep on pressing F8 till the menu appears and choose safe mode. As Ken said, then upload the .dmp files or take a look at the guide in my sig. Is this a dell laptop or pc and what are the specs? You can use Belarc Advisor to pull up a report.
    Sony Vaio Z46GDU
    6GB DDR3 1066MHz SDRAM
    13.1" WXGA True Colour Tough
    1600x900
    320GB SATA 7200RPM
    1MB/s
its a dell laptop with vista home premium
OK
which dell. mine is an inspiron and its f8 for safe boot and f2 to boot into setup
    [email protected]
    4 gigs
    integrated
    300 gig internal
    10 down 1.5 up
its a inspiron 1525
Same as mine. so what is it thats giving you blue screen? can you go into c:\windows\minidump, zip the dump file (*dmp) and upload it for us to analyze?
Ken
    [email protected]
    4 gigs
    integrated
    300 gig internal
    10 down 1.5 up
    Sony Vaio Z46GDU
    1600x900
    320GB SATA 7200RPM
    1MB/s
when i do that i get the message windows cannot compress folder here and ask place one desktop instead?
Choose yes.
    Sony Vaio Z46GDU
    1600x900
    320GB SATA 7200RPM
    1MB/s
Right-click the file, click copy, then right-click on desktop and then select paste. Accept the UAC prompt. Then zip it up.
    Sony Vaio Z46GDU
    1600x900
    320GB SATA 7200RPM
    1MB/s
Bugcheck:
* Bugcheck Analysis *
BugCheck F4, {3, 874df988, 874dfad4, 81e5e650}
Probably caused by : wininit.exe
Followup: MachineOwner
0: kd> !analyze -v
CRITICAL_OBJECT_TERMINATION (f4)
A process or thread crucial to system operation has unexpectedly exited or been
terminated.
Several processes and threads are necessary for the operation of the
system; when they are terminated (for any reason), the system can no
longer function.
Arguments:
Arg1: 00000003, Process
Arg2: 874df988, Terminating object
Arg3: 874dfad4, Process image file name
Arg4: 81e5e650, Explanatory message (ascii)
Debugging Details:
PROCESS_OBJECT: 874df988
DEBUG_FLR_IMAGE_TIMESTAMP: 0
MODULE_NAME: wininit
FAULTING_MODULE: 00000000
PROCESS_NAME: WerFault.exe
BUGCHECK_STR: 0xF4_WerFault.exe
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
CURRENT_IRQL: 0
LAST_CONTROL_TRANSFER: from 81eca610 to 81d05b0d
STACK_TEXT:
8fb91ccc 81eca610 000000f4 00000003 874df988 nt!KeBugCheckEx+0x1e
8fb91cf0 81e28f77 81e5e650 874dfad4 874dfbb0 nt!PspCatchCriticalBreak+0x73
8fb91d20 81e28f1e 874df988 8850ac40 000000ff nt!PspTerminateAllThreads+0x2c
8fb91d54 81c82c7a 000000b0 000000ff 0019e618 nt!NtTerminateProcess+0x1c1
8fb91d54 77cb5e74 000000b0 000000ff 0019e618 nt!KiFastCallEntry+0x12a
WARNING: Frame IP not in any known module. Following frames may be wrong.
0019e618 00000000 00000000 00000000 00000000 0x77cb5e74
STACK_COMMAND: kb
FOLLOWUP_NAME: MachineOwner
IMAGE_NAME: wininit.exe
FAILURE_BUCKET_ID: 0xF4_WerFault.exe_IMAGE_wininit.exe
The BugCheck_Str references a critical termination of wininit.exe. Since its a crucial system file, you probably have a virus infection unless you deliberately terminated wininit.exe.
Download a antivirus rescue disc from here: http://www.free-av.com/en/tools/12/avira_antivir_rescue_system.html
burn it to disc and then reboot with the disc in the drive. Then scan your pc, and that should allow you to boot into safe mode and run a thorough scan.
    Sony Vaio Z46GDU
    1600x900
    320GB SATA 7200RPM
    1MB/s
how can i have a virus infection? avg, windows defender, and the free live safety live one care scanner report nothing found.
As above, no app can catch anything. Try the boot disk. Something crashed a crucial process.
    Sony Vaio Z46GDU
    1600x900
    320GB SATA 7200RPM
    1MB/s
