driver_irql equal or not less..blue screen...help plz
black mamba
Hey guys,
Recently, my computer is showing me the blue screen of death, and it just happen now, so I took note of what it said. This time it said DRIVER IRQL EQUAL OR NOT LESS THAN or something, and at the bottom said something about NId.sys or something. One of the errors also said "BUGCODE USB ERROR" or something like that.....help plzz ..how can i fix this prob??
Hello Black Mamba,
Since this has just happened. You might see if doing a System Restore using a restore point dated before this happened can fix it for you.
Black Mamba,
You can try a restore point that is dated further back to see if that will help.
This error is usually for a driver or hardware problem for a device that you just installed. Uninstalling the device, or rolling back the driver can usually help as well.
Most certainly, and this is a good reason to take an extra few minutes and create a restor point just prior to adding hardware, even new programs. It has saved me more than once.
    Asus G50Vt plus two XP shop machines used for trouble-shooting client problems
