Forum Noob Needs Help - Blue Screen Of Death
Gremlin00
Hi guys,
I know its my first post on these forums, and of course it had to be a problem, lol. Anyway i just needed help in determining what was the problem with my system.
I have just recently put in new RAM (4gb HyperX ddr 800) into my system and i have gotten the Blue Screen of Death 3 times in as many days. I run Vista Home Basic and i am wondering if that and the 4gb of new ram are the problem. I was under the impression that SP1 has resolved the problem with having more than 3gb of RAM for 32 bit systems. Is this not the case? Or is it because Vista now recognizes 4GB but still only effectively uses 3GB and the extra 1GB causes conflict when whatever program i am running "reaches" for it. I notice i usually only get the Blue Screen of Death when i am Playing WoW or America's Army and the in-game environment is getting really crowded or heavy.
I have not tried removing one of the 2GB sticks yet to see if that helps, i was just wondering if anyone here could help before i went down that road or went out to go get the 64 bit Vista upgrade. Sorry to annoy everyone with my Nooby questions and thanks for any help you can throw my way. :)
    AMD AM2 x2 6000+
    ASUS M2N SLI Deluxe
    4GB DDR2 800 Kingston Hyper X
    Asus 8600 GT SLI
    Maxtor 320 GB Sata Maxtor 500 GB External
Hi Gremlin00
Welcome to the forums.
Far as I know 32-bit systems won't use more than 3 gig. This should not cause blue screen of death though. Take them out and put in your old sticks of memory and run it for a while. If not BSOD then guess your new ram sticks are bad. I personally like to go to Kingston.com and check for compatibility.
Raj
Hi guys,
Welcome to the Vista Forums :party:
The 4GB of ram should be ok for the x86 environment. I run x86 myself, and my system reports 4GB, but only uses 3.3GB (the other .7GB is used by the video system). I've also run WOW and haven't come across the BSOD.
We've got a new tool here that helps us help you. It's a sysinfo tool. Here's the link for the download: http://www.vistax64.com/tutorials/176785-vistaforums-sysinfo-tool.html
I'd recommend downloading, installing, running and then posting your results. It could provide us with valuable information on troubleshooting your issue.
    Intel Q6600 Quad Core 2.4 Ghz
    Dell 0TP406
    Nvidia 8800 GT 512 MB
    Dual Dell 22" Widescreen
    3360x1050
    320 GB Internal Main 500 GB USB External 160 GB USB External 2TB USB External
    DSL 3MB
    Fumz' Flux-Capacitor
    E8400
    DFI LP DK P35-T2RS
    4GB G.Skill PC-1066
    eVGA 8800 GTS
    X-Fi XtremeGamer
    Samsung 226BW
    500GB W.D. RE2 Primary 1TB W.D. Caviar GP WD10EACS
    Lian Li Lancool K62
    Logitech G5
    2.5MB/430
    D-Link DGL 4500
Thanks guys will give all that a try and see how i go. Thanks.
    AMD AM2 x2 6000+
    ASUS M2N SLI Deluxe
    Asus 8600 GT SLI
Sorry it took me a while to post this guys had something else come up and just been tied down elsewhere, anyway here is the result of the Vista tool u guys recommended
Code:
********************** Computer Info ************************
Logged in user: GRIMMY001\user
Computer Model: System Product Name
Computer Manufacturer: System manufacturer
OS Name: Microsoft® Windows Vista™ Home Basic |C:\Windows|\Device\Harddisk0\Partition1
OS Version: 6.0.6001
System Type: X86-based PC
Total Physical Memory: 3070 MB
Windows Directory: C:\Windows
BIOS Version: Phoenix - AwardBIOS v6.00PG
CPU: AMD Athlon(tm) 64 X2 Dual Core Processor 6000+
Video Card: NVIDIA GeForce 8600 GT
Resolution: 1280 x 960 x 4294967296 colors
*********************** UAC Status **************************
UAC is currently enabled
***************** Installed Applications ********************
Try Corel Snapfire muvee autoProducer add on - Location: C:\Program Files\Common Files\Corel\Modules\muvee Module\
Windows Media Player Firefox Plugin - Location:
Corel Snapfire DVD Maker - Location: C:\Program Files\Common Files\Corel\Modules\DVD Module\
KhalInstallWrapper - Location: C:\Program Files\Logitech\KhalInstallWrapper\
CDDRV_Installer - Location: C:\Program Files\Logitech\My Product Name\
neroxml - Location:
Compatibility Pack for the 2007 Office system - Location:
AIO_CDB_ProductContext - Location:
DocProc - Location:
HPSSupply - Location: C:\Program Files\HP\
Copy - Location:
Camera Window DVC - Location:
HPProductAssistant - Location:
MSXML 4.0 SP2 (KB936181) - Location:
WinZip 11.1 - Location: C:\Program Files\WinZip\
MovieEdit Task - Location: E:\SOFTWARE\MVW\ENGLISH
Microsoft SQL Server 2005 Compact Edition [ENU] - Location: C:\Program Files\Microsoft SQL Server Compact Edition\
Windows Live Favorites for Windows Live Toolbar - Location:
Fax - Location:
HP Photosmart Essential - Location: C:\Program Files\HP\Photosmart Essential\
Highlight Viewer (Windows Live Toolbar) - Location:
RAW Image Task 2.2 - Location:
AIO_CDB_Software - Location:
32 Bit HP CIO Components Installer - Location:
Windows Live Photo Gallery - Location:
PhotoStitch - Location: C:\Program Files\Canon\PhotoStitch\
WebReg - Location:
Windows Live Toolbar Extension (Windows Live Toolbar) - Location:
QuickTime - Location: C:\Program Files\QuickTime\
Camera Window DS - Location:
SolutionCenter - Location:
Windows Live Messenger - Location:
MSXML 4.0 SP2 (KB941833) - Location:
DocProcQFolder - Location:
Adobe Reader 8.1.2 - Location:
1310 - Location:
Camera Window MC - Location:
HP Update - Location:
Camera Access Library - Location:
Windows Live Mail - Location:
TrayApp - Location:
Java(TM) 6 Update 2 - Location:
Java(TM) 6 Update 3 - Location:
Java(TM) 6 Update 5 - Location:
Java(TM) 6 Update 7 - Location:
Microsoft Office XP Standard - Location:
Microsoft Office XP Professional with FrontPage - Location:
Scan - Location:
Canon PhotoRecord - Location:
UnloadSupport - Location:
Windows Live Writer - Location:
Camera Support Core Library - Location:
Canon ZoomBrowser EX (E) - Location: C:\Program Files\Canon\ZoomBrowser EX\Program\
Apple Mobile Device Support - Location: C:\Program Files\Common Files\Apple\Mobile Device Support\
Ventrilo Client - Location:
Windows Live installer - Location:
Ad-Aware 2007 - Location: C:\Program Files\Lavasoft\Ad-Aware 2007\
Microsoft Visual C++ 2005 Redistributable - Location:
America's Army - Location: D:\Americas Army\
Logitech QuickCam - Location: C:\Program Files\Logitech\QuickCam\
AIO_Scan - Location:
eSupportQFolder - Location:
1310Trb - Location:
Toolbox - Location:
Smart Menus (Windows Live Toolbar) - Location:
Bonjour - Location: C:\Program Files\Bonjour\
Nero 7 Ultra Edition - Location: C:\Program Files\Nero\Nero 7\
Microsoft Silverlight - Location:
iPod for Windows 2006-03-23 - Location: C:\Program Files\iPod\
Windows Live Sign-in Assistant - Location:
MobileMe Control Panel - Location: C:\Program Files\Common Files\Apple\Mobile Device Support\
DeviceManagementQFolder - Location:
Destinations - Location:
Status - Location:
BufferChm - Location:
Apple Software Update - Location: C:\Program Files\Apple Software Update\
iTunes - Location: C:\Program Files\iTunes\
1310_Help - Location:
************************* Services **************************
Name: Ad-Aware 2007 Service
Path: "C:\Program Files\Lavasoft\Ad-Aware 2007\aawservice.exe"
StartMode: Auto
State: Running
Name: Application Experience
Path: C:\Windows\system32\svchost.exe -k netsvcs
StartMode: Auto
State: Running
Name: Application Layer Gateway Service
Path: C:\Windows\System32\alg.exe
StartMode: Manual
State: Stopped
Name: Application Information
StartMode: Manual
State: Running
Name: Apple Mobile Device
Path: "C:\Program Files\Common Files\Apple\Mobile Device Support\bin\AppleMobileDeviceService.exe"
StartMode: Auto
State: Running
Name: Windows Audio Endpoint Builder
Path: C:\Windows\System32\svchost.exe -k LocalSystemNetworkRestricted
StartMode: Auto
State: Running
Path: C:\Windows\System32\svchost.exe -k LocalServiceNetworkRestricted
StartMode: Auto
State: Running
Name: AVG Free8 WatchDog
Path: C:\PROGRA~1\AVG\AVG8\avgwdsvc.exe
StartMode: Auto
State: Running
Name: Base Filtering Engine
Path: C:\Windows\system32\svchost.exe -k LocalServiceNoNetwork
StartMode: Auto
State: Running
Name: Background Intelligent Transfer Service
Path: C:\Windows\System32\svchost.exe -k netsvcs
StartMode: Auto
State: Running
Path: "C:\Program Files\Bonjour\mDNSResponder.exe"
StartMode: Auto
State: Running
StartMode: Auto
State: Running
Name: Canon Camera Access Library 8
Path: C:\Program Files\Canon\CAL\CALMAIN.exe
StartMode: Auto
State: Running
Name: Certificate Propagation
StartMode: Manual
State: Stopped
Name: Microsoft .NET Framework NGEN v2.0.50727_X86
Path: C:\Windows\Microsoft.NET\Framework\v2.0.50727\mscorsvw.exe
StartMode: Manual
State: Stopped
Name: COM+ System Application
Path: C:\Windows\system32\dllhost.exe /Processid:{02D4B3F1-FD88-11D1-960D-00805FC79235}
StartMode: Manual
State: Stopped
Path: C:\Windows\system32\svchost.exe -k NetworkService
StartMode: Auto
State: Running
Name: DCOM Server Process Launcher
Path: C:\Windows\system32\svchost.exe -k DcomLaunch
StartMode: Auto
State: Running
Name: DFS Replication
Path: C:\Windows\system32\DFSR.exe
StartMode: Manual
State: Stopped
Path: C:\Windows\system32\svchost.exe -k LocalServiceNetworkRestricted
StartMode: Auto
State: Running
StartMode: Auto
State: Running
Name: Wired AutoConfig
Path: C:\Windows\system32\svchost.exe -k LocalSystemNetworkRestricted
StartMode: Manual
State: Stopped
Name: Diagnostic Policy Service
Path: C:\Windows\System32\svchost.exe -k LocalServiceNoNetwork
StartMode: Auto
State: Running
Name: Extensible Authentication Protocol
StartMode: Manual
State: Stopped
StartMode: Auto
State: Running
Name: Windows Event Log
StartMode: Auto
State: Running
Name: COM+ Event System
StartMode: Auto
State: Running
Path: "C:\Program Files\Optus Internet Security Suite\Anti-Virus\fsgk32st.exe"
StartMode: Auto
State: Stopped
Name: Function Discovery Provider Host
StartMode: Manual
State: Stopped
Name: Function Discovery Resource Publication
StartMode: Auto
State: Running
Name: Windows Presentation Foundation Font Cache 3.0.0.0
Path: C:\Windows\Microsoft.Net\Framework\v3.0\WPF\PresentationFontCache.exe
StartMode: Manual
State: Stopped
Name: F-Secure Automatic Update Agent
Path: "C:\Program Files\Optus Internet Security Suite\FSAUA\program\fsaua.exe"
StartMode: Manual
State: Running
Name: F-Secure Anti-Virus Firewall Daemon
Path: "C:\Program Files\Optus Internet Security Suite\FWES\Program\fsdfwd.exe"
StartMode: Manual
State: Running
Name: F-Secure Management Agent
Path: "C:\Program Files\Optus Internet Security Suite\Common\FSMA32.EXE"
StartMode: Auto
State: Running
Name: Group Policy Client
StartMode: Auto
State: Running
Name: Human Interface Device Access
StartMode: Auto
State: Running
Name: Health Key and Certificate Management
StartMode: Manual
State: Stopped
Path: C:\Windows\system32\svchost.exe -k hpdevmgmt
StartMode: Manual
State: Running
Name: HP CUE DeviceDiscovery Service
StartMode: Auto
State: Running
Name: InstallDriver Table Manager
Path: "C:\Program Files\Common Files\InstallShield\Driver\11\Intel 32\IDriverT.exe"
StartMode: Manual
State: Stopped
Name: Windows CardSpace
Path: "C:\Windows\Microsoft.NET\Framework\v3.0\Windows Communication Foundation\infocard.exe"
StartMode: Manual
State: Stopped
Name: IKE and AuthIP IPsec Keying Modules
StartMode: Auto
State: Running
Name: PnP-X IP Bus Enumerator
StartMode: Manual
State: Stopped
Path: C:\Windows\System32\svchost.exe -k NetSvcs
StartMode: Auto
State: Running
Path: "C:\Program Files\iPod\bin\iPodService.exe"
StartMode: Manual
State: Running
Name: CNG Key Isolation
Path: C:\Windows\system32\lsass.exe
StartMode: Manual
State: Stopped
Name: KtmRm for Distributed Transaction Coordinator
Path: C:\Windows\System32\svchost.exe -k NetworkService
StartMode: Auto
State: Running
StartMode: Auto
State: Running
StartMode: Auto
State: Running
Name: Link-Layer Topology Discovery Mapper
StartMode: Manual
State: Stopped
Name: TCP/IP NetBIOS Helper
StartMode: Auto
State: Running
Path: "C:\Program Files\Common Files\LogiShrd\LVCOMSER\LVComSer.exe"
StartMode: Auto
State: Running
Path: "C:\Program Files\Common Files\LogiShrd\LVMVFM\LVPrcSrv.exe"
StartMode: Auto
State: Running
Path: C:\Program Files\Common Files\LogiShrd\SrvLnch\SrvLnch.exe
StartMode: Auto
State: Stopped
Name: Machine Debug Manager
Path: "C:\Program Files\Common Files\Microsoft Shared\VS7DEBUG\MDM.EXE"
StartMode: Auto
State: Running
Name: Multimedia Class Scheduler
StartMode: Auto
State: Running
StartMode: Auto
State: Running
Name: Distributed Transaction Coordinator
Path: C:\Windows\System32\msdtc.exe
StartMode: Manual
State: Stopped
Name: Microsoft iSCSI Initiator Service
StartMode: Manual
State: Stopped
Name: Windows Installer
Path: C:\Windows\system32\msiexec /V
StartMode: Manual
State: Running
Name: Network Access Protection Agent
StartMode: Manual
State: Stopped
Path: C:\Program Files\Nero\Nero 7\Nero BackItUp\NBService.exe
StartMode: Manual
State: Stopped
Name: Net Driver HPZ12
Path: C:\Windows\System32\svchost.exe -k HPZ12
StartMode: Auto
State: Running
StartMode: Manual
State: Stopped
Name: Network Connections
StartMode: Manual
State: Running
Name: Network List Service
StartMode: Auto
State: Running
Name: Net.Tcp Port Sharing Service
Path: "C:\Windows\Microsoft.NET\Framework\v3.0\Windows Communication Foundation\SMSvcHost.exe"
StartMode: Disabled
State: Stopped
Name: Network Location Awareness
StartMode: Auto
State: Running
Path: "C:\Program Files\Common Files\Ahead\Lib\NMIndexingService.exe"
StartMode: Manual
State: Running
Name: Network Store Interface Service
StartMode: Auto
State: Running
Name: Peer Networking Identity Manager
StartMode: Manual
State: Stopped
Name: Peer Networking Grouping
StartMode: Manual
State: Stopped
Name: Program Compatibility Assistant Service
StartMode: Auto
State: Running
Name: Performance Logs & Alerts
StartMode: Manual
State: Stopped
Name: Plug and Play
StartMode: Auto
State: Running
Name: Pml Driver HPZ12
StartMode: Auto
State: Running
Path: C:\Windows\system32\PnkBstrA.exe
StartMode: Auto
State: Running
Name: PNRP Machine Name Publication Service
StartMode: Manual
State: Stopped
Name: Peer Name Resolution Protocol
StartMode: Manual
State: Stopped
Name: IPsec Policy Agent
Path: C:\Windows\system32\svchost.exe -k NetworkServiceNetworkRestricted
StartMode: Auto
State: Running
Name: User Profile Service
StartMode: Auto
State: Running
StartMode: Manual
State: Running
Path: C:\Windows\system32\PSIService.exe
StartMode: Auto
State: Running
Name: Quality Windows Audio Video Experience
StartMode: Manual
State: Stopped
Name: Remote Access Auto Connection Manager
StartMode: Manual
State: Stopped
Name: Remote Access Connection Manager
StartMode: Manual
State: Running
Name: Routing and Remote Access
StartMode: Disabled
State: Stopped
Path: C:\Windows\system32\svchost.exe -k regsvc
StartMode: Manual
State: Stopped
Name: Cyberlink RichVideo Service(CRVS)
Path: "C:\Program Files\CyberLink\Shared Files\RichVideo.exe"
StartMode: Auto
State: Running
Name: Remote Procedure Call (RPC) Locator
Path: C:\Windows\system32\locator.exe
StartMode: Manual
State: Stopped
Path: C:\Windows\system32\svchost.exe -k rpcss
StartMode: Auto
State: Running
Name: Security Accounts Manager
StartMode: Auto
State: Running
StartMode: Manual
State: Stopped
Name: Task Scheduler
StartMode: Auto
State: Running
Name: Smart Card Removal Policy
StartMode: Manual
State: Stopped
Path: C:\Windows\system32\svchost.exe -k SDRSVC
StartMode: Manual
State: Stopped
StartMode: Auto
State: Running
Name: System Event Notification Service
StartMode: Auto
State: Running
Name: Terminal Services Configuration
StartMode: Manual
State: Stopped
Name: Internet Connection Sharing (ICS)
StartMode: Disabled
State: Stopped
Name: Shell Hardware Detection
StartMode: Auto
State: Running
Name: Software Licensing
Path: C:\Windows\system32\SLsvc.exe
StartMode: Auto
State: Running
Name: SL UI Notification Service
StartMode: Manual
State: Stopped
Path: C:\Windows\System32\snmptrap.exe
StartMode: Manual
State: Stopped
Path: C:\Windows\System32\spoolsv.exe
StartMode: Auto
State: Running
Name: SSDP Discovery
StartMode: Manual
State: Running
Name: Secure Socket Tunneling Protocol Service
StartMode: Manual
State: Running
Name: Windows Image Acquisition (WIA)
Path: C:\Windows\system32\svchost.exe -k imgsvc
StartMode: Auto
State: Running
Name: Microsoft Software Shadow Copy Provider
Path: C:\Windows\System32\svchost.exe -k swprv
StartMode: Manual
State: Stopped
StartMode: Auto
State: Running
Name: Tablet PC Input Service
StartMode: Auto
State: Running
StartMode: Manual
State: Running
Name: TPM Base Services
StartMode: Auto
State: Stopped
StartMode: Auto
State: Running
StartMode: Auto
State: Running
Name: Thread Ordering Server
StartMode: Manual
State: Stopped
Name: Distributed Link Tracking Client
StartMode: Auto
State: Running
Name: Windows Modules Installer
Path: C:\Windows\servicing\TrustedInstaller.exe
StartMode: Manual
State: Stopped
Name: Interactive Services Detection
Path: C:\Windows\system32\UI0Detect.exe
StartMode: Manual
State: Stopped
Name: UPnP Device Host
StartMode: Manual
State: Running
Name: Messenger Sharing Folders USN Journal Reader service
Path: "C:\Program Files\Windows Live\Messenger\usnsvc.exe"
StartMode: Manual
State: Stopped
Name: Desktop Window Manager Session Manager
StartMode: Auto
State: Running
Path: C:\Windows\System32\vds.exe
StartMode: Manual
State: Stopped
Name: Volume Shadow Copy
Path: C:\Windows\system32\vssvc.exe
StartMode: Manual
State: Stopped
StartMode: Auto
State: Running
Name: Windows Connect Now - Config Registrar
StartMode: Manual
State: Stopped
Name: Windows Color System
Path: C:\Windows\system32\svchost.exe -k wcssvc
StartMode: Manual
State: Stopped
Name: Diagnostic Service Host
Path: C:\Windows\System32\svchost.exe -k wdisvc
StartMode: Manual
State: Stopped
Name: Diagnostic System Host
StartMode: Manual
State: Running
StartMode: Auto
State: Running
Name: Windows Event Collector
StartMode: Manual
State: Stopped
Name: Problem Reports and Solutions Control Panel Support
StartMode: Manual
State: Stopped
Name: Windows Error Reporting Service
Path: C:\Windows\System32\svchost.exe -k WerSvcGroup
StartMode: Auto
State: Running
Path: C:\Windows\System32\svchost.exe -k secsvcs
StartMode: Auto
State: Running
Name: WinHTTP Web Proxy Auto-Discovery Service
StartMode: Manual
State: Stopped
Name: Windows Management Instrumentation
StartMode: Auto
State: Running
Name: Windows Remote Management (WS-Management)
StartMode: Manual
State: Stopped
Name: WLAN AutoConfig
StartMode: Manual
State: Stopped
Name: Windows Live Setup Service
Path: "C:\Program Files\Windows Live\installer\WLSetupSvc.exe"
StartMode: Manual
State: Stopped
Name: WMI Performance Adapter
Path: C:\Windows\system32\wbem\WmiApSrv.exe
StartMode: Manual
State: Stopped
Name: Windows Media Player Network Sharing Service
Path: "C:\Program Files\Windows Media Player\wmpnetwk.exe"
StartMode: Manual
State: Running
StartMode: Manual
State: Stopped
Name: Portable Device Enumerator Service
StartMode: Auto
State: Running
StartMode: Auto
State: Running
Path: C:\Windows\system32\SearchIndexer.exe /Embedding
StartMode: Auto
State: Running
StartMode: Auto
State: Running
Name: Windows Driver Foundation - User-mode Driver Framework
StartMode: Auto
State: Running
******************** Installed Codecs ***********************
Name: C:\Windows\system32\LVCODEC2.DLL Description:
Version: 8.4.7.1032
Path: \windows\system32\
FileName: lvcodec2
Name: C:\Windows\system32\TSBYUV.DLL Description:
Version: 6.0.6000.16386
FileName: tsbyuv
Name: C:\Windows\system32\IYUV_32.DLL Description:
FileName: iyuv_32
Name: C:\Windows\system32\MSYUV.DLL Description:
FileName: msyuv
Name: C:\Windows\system32\MSADP32.ACM Description:
FileName: msadp32
Name: C:\Windows\system32\MSGSM32.ACM Description:
FileName: msgsm32
Name: C:\Windows\system32\MSG711.ACM Description:
FileName: msg711
Name: C:\Windows\system32\IMAADP32.ACM Description:
FileName: imaadp32
Name: C:\Windows\system32\MSVIDC32.DLL Description:
Version: 6.0.6001.18000
FileName: msvidc32
Name: C:\Windows\system32\MSRLE32.DLL Description:
FileName: msrle32
Name: C:\Windows\system32\L3CODECA.ACM Description: Fraunhofer IIS MPEG Layer-3 Codec
Version: 1.9.0.401
FileName: l3codeca
Name: C:\Windows\system32\ICCVID.DLL Description:
Version: 1.10.0.12
FileName: iccvid
Name: C:\Windows\system32\LHACM.ACM Description: lhacm.acm
Version: 4.4.0.3385
FileName: lhacm
Name: C:\Windows\system32\ITIG726.ACM Description: ITI G.726 Audio Codec
Version: 4.0.0.0
FileName: itig726
Name: C:\Windows\system32\IR50_32.DLL Description: Indeo® video 5.10
Version: 5.2562.15.55
FileName: ir50_32
Name: C:\Windows\system32\IR41_32.AX Description: Indeo® video interactive R4.3 by Intel
Version: 4.51.16.3
FileName: ir41_32
Name: C:\Windows\system32\IR32_32.DLL Description: Indeo® video R3.2 by Intel
Version: 3.24.15.3
FileName: ir32_32
Name: C:\Windows\system32\MPG4C32.DLL Description: MS MPEG-4 v1,2,3 driver 4.1.0.3927
Version: 4.1.0.3927
FileName: mpg4c32
Name: C:\Windows\system32\MSAUD32.ACM Description: Windows Media Audio Codec
Version: 4.1.0.3917
FileName: msaud32
Name: C:\Windows\system32\SL_ANET.ACM Description: Sipro Lab Telecom Audio Codec
Version: 2.8.0.0
FileName: sl_anet
Name: C:\Windows\system32\SIRENACM.DLL Description: Messenger Audio Codec
Version: 8.5.1302.1018
FileName: sirenacm
Name: C:\Windows\system32\VCT3216.ACM Description: Voxware Compression Toolkit
Version: 1.6.0.17
FileName: vct3216
Name: C:\Windows\system32\SCG726.ACM Description: Sharp G.726 Audio Decoder
Version: 1.0.0.3
FileName: scg726
Name: C:\Windows\system32\ALF2CD.ACM Description: alf2cd.acm
Version: 2.3.1.0
FileName: alf2cd
Name: C:\Windows\system32\AC3ACM.ACM Description: AC-3 ACM Decompressor
Version: 0.7.0.0
FileName: ac3acm
Name: C:\Windows\system32\MCDVD_32.DLL Description: mcdvd_32.dll
Version: 2.0.0.0
FileName: mcdvd_32
Name: C:\Windows\system32\XVIDVFW.DLL Description: XviD MPEG-4 Video Codec
Version:
FileName: xvidvfw
Name: C:\Windows\system32\DIVX.DLL Description: DivX 5.0.5 Codec
Version: 5.0.5.830
FileName: divx
*********************** Hot Fixes ***************************
Description:
HotFixID: {026C2636-B788-409C-B178-A7603289EC2A}
Description:
HotFixID: {1AFF2298-CC00-4A3B-866A-C62B8373794E}
Description:
HotFixID: {5F7F6FFF-395D-480E-8450-64F385D82C5F}
Description:
HotFixID: {63193DF7-81DB-46C9-A908-06B2296AB87F}
Description:
HotFixID: {797AE457-BA17-4BBC-B501-25FB3A0103C7}
Description:
HotFixID: {8F375E11-4FD6-4B89-9E2B-A76D48B51E00}
Description:
HotFixID: {36FE6700-97C3-4CE4-BC23-B7A127BC3987}
Description:
HotFixID: {DA256408-A2E7-41A5-8AD6-62ACB86A0FD7}
Description:
HotFixID: {106E7A1C-22DA-42D7-8E74-37772A9C89FB}
Description:
HotFixID: {150A5667-2171-4D5C-ABE5-17BA5049BB55}
Description:
HotFixID: {17342715-5BEE-452F-BDA4-D088DE65EF7E}
Description:
HotFixID: {2CB5D4F9-0B93-4BBF-BFB7-A96C26CEE63E}
Description:
HotFixID: {4D072D56-B07B-4798-97B2-B9E7A4F53EAC}
Description:
HotFixID: {60556C49-6363-4A37-B4E4-2F6DB6C65567}
Description:
HotFixID: {6A6A5A40-FB6D-402C-8516-CC61E6DFE524}
Description:
HotFixID: {923D89F2-B3D7-4530-8165-309F1DE72706}
Description:
HotFixID: {9716E16B-BAA5-4C65-95CF-CA6B60AA922D}
Description:
HotFixID: {B945219C-C51C-4BD0-BAD5-A3FED95B555F}
Description:
HotFixID: {C602034B-0E04-4A4C-994B-9BE7AEFF5931}
Description:
HotFixID: {CEB1A88D-195D-4350-A550-C6807B1BBB17}
Description:
HotFixID: {F14D124D-6DD4-4A59-8A23-075B92ED2C4C}
Description:
HotFixID: {F5001920-E94E-4287-80C6-158FBC1D7035}
Description:
HotFixID: {FA111F3D-A299-438D-A61F-2E8D5138D1D2}
Description:
HotFixID: {32971938-65B1-4B38-B483-9A32560B7CF2}
Description:
HotFixID: {B0AEF410-04FF-4AEC-8D8E-C9427C38BBCD}
Description:
HotFixID: {9DFD0865-4E0F-4947-A77D-43D58782A57F}
Description:
Description:
Description:
Description:
Description:
Description:
Description:
Description:
Description:
Description:
Description:
Description:
Description:
Description:
HotFixID: {D3EFC280-3E7E-45E8-AA78-6FC148A08B62}
Description:
Description:
Description:
Description:
Description:
Description:
Description:
HotFixID: {18224A8C-3338-4914-AB89-23BC204FC52C}
Description:
HotFixID: {2F1F95D4-C1D4-4B76-9E04-9DAF45413C9B}
Description: Security Update
HotFixID: KB925902
Description: Update
HotFixID: KB929399
Description: Update
HotFixID: KB929735
HotFixID: KB930178
Description: Update
HotFixID: KB930857
Description: Update
HotFixID: KB931099
Description: Update
HotFixID: KB931573
Description: Hotfix
HotFixID: KB932471
HotFixID: KB933579
HotFixID: KB933729
HotFixID: KB936021
HotFixID: KB936782
Description: Update
HotFixID: KB936825
Description: Update
HotFixID: KB937077
HotFixID: KB938127
Description: Update
HotFixID: KB939159
Description: Hotfix
HotFixID: KB940105
HotFixID: KB941202
HotFixID: KB941568
HotFixID: KB941569
Description: Update
HotFixID: KB941600
HotFixID: KB941644
HotFixID: KB943055
HotFixID: KB943078
HotFixID: KB945553
HotFixID: KB946026
HotFixID: KB946456
Description: Update
HotFixID: KB905866
HotFixID: KB929123
HotFixID: KB929916
HotFixID: KB931213
Description: Update
HotFixID: KB933360
Description: Update
HotFixID: KB933928
Description: Update
HotFixID: KB935280
HotFixID: KB935807
Description: Update
HotFixID: KB936824
Description: Update
HotFixID: KB937287
HotFixID: KB938123
Description: Update
HotFixID: KB938194
Description: Update
HotFixID: KB938371
HotFixID: KB938464
Description: Update
HotFixID: KB938979
HotFixID: KB939653
Description: Update
HotFixID: KB941649
Description: Update
HotFixID: KB941651
HotFixID: KB941693
HotFixID: KB942615
HotFixID: KB942624
Description: Update
HotFixID: KB942763
Description: Update
HotFixID: KB943302
HotFixID: KB943411
Description: Update
HotFixID: KB943899
HotFixID: KB944533
Description: Update
HotFixID: KB946041
Description: Update
HotFixID: KB947562
HotFixID: KB947864
HotFixID: KB948590
HotFixID: KB948881
HotFixID: KB950582
HotFixID: KB950759
HotFixID: KB950760
HotFixID: KB950762
HotFixID: KB950974
HotFixID: KB951066
Description: Update
HotFixID: KB951072
HotFixID: KB951376
Description: Update
HotFixID: KB951618
HotFixID: KB951698
Description: Update
HotFixID: KB951978
Description: Hotfix
HotFixID: KB952287
Description: Update
HotFixID: KB952709
HotFixID: KB953733
HotFixID: KB953838
HotFixID: KB953839
HotFixID: KB954154
Description: Update
HotFixID: KB954366
Description: Update
HotFixID: KB955020
Description: Update
HotFixID: KB955302
Description: Service Pack
HotFixID: KB936330
Description: Update
HotFixID: 940157
************************* Event Log *************************
Application - 9/15/2008 5:28:48 PM: Windows Installer reconfigured the product. Product Name: MobileMe Control Panel. Product Version: 2.1.0.24. Product Language: 1033. Reconfiguration success or error status: 0.
Application - 9/15/2008 5:28:48 PM: Windows Installer reconfigured the product. Product Name: Camera Window DVC. Product Version: 5.4.4. Product Language: 1033. Reconfiguration success or error status: 0.
Application - 9/15/2008 5:28:48 PM: Windows Installer reconfigured the product. Product Name: DeviceManagementQFolder. Product Version: 1.00.0000. Product Language: 1033. Reconfiguration success or error status: 0.
Application - 9/15/2008 5:28:48 PM: Windows Installer reconfigured the product. Product Name: Destinations. Product Version: 82.0.173.000. Product Language: 1033. Reconfiguration success or error status: 0.
Application - 9/15/2008 5:28:48 PM: Windows Installer reconfigured the product. Product Name: Status. Product Version: 82.0.173.000. Product Language: 1033. Reconfiguration success or error status: 0.
Application - 9/15/2008 5:28:48 PM: Windows Installer reconfigured the product. Product Name: BufferChm. Product Version: 82.0.173.000. Product Language: 1033. Reconfiguration success or error status: 0.
Application - 9/15/2008 5:28:48 PM: Windows Installer reconfigured the product. Product Name: Apple Software Update. Product Version: 2.1.1.116. Product Language: 1033. Reconfiguration success or error status: 0.
Application - 9/15/2008 5:28:48 PM: Windows Installer reconfigured the product. Product Name: Microsoft Visual C++ 2005 Redistributable. Product Version: 8.0.50727.42. Product Language: 0. Reconfiguration success or error status: 0.
Application - 9/15/2008 5:28:49 PM: Windows Installer reconfigured the product. Product Name: iTunes. Product Version: 8.0.0.35. Product Language: 1033. Reconfiguration success or error status: 0.
Application - 9/15/2008 5:28:49 PM: Windows Installer reconfigured the product. Product Name: 1310_Help. Product Version: 82.0.58.000. Product Language: 1033. Reconfiguration success or error status: 0.
Security - 9/15/2008 5:00:44 PM: The description for Event ID '4648' in Source 'Microsoft-Windows-Security-Auditing' cannot be found.  The local computer may not have the necessary registry information or message DLL files to display the message, or you may not have permission to access them.  The following information is part of the event:'S-1-5-18', 'GRIMMY001$', 'WORKGROUP', '0x3e7', '{00000000-0000-0000-0000-000000000000}', 'user', 'GRIMMY001', '{00000000-0000-0000-0000-000000000000}', 'localhost', 'localhost', '0x334', 'C:\Windows\System32\winlogon.exe', '127.0.0.1', '0'
Security - 9/15/2008 5:00:44 PM: The description for Event ID '4624' in Source 'Microsoft-Windows-Security-Auditing' cannot be found.  The local computer may not have the necessary registry information or message DLL files to display the message, or you may not have permission to access them.  The following information is part of the event:'S-1-5-18', 'GRIMMY001$', 'WORKGROUP', '0x3e7', 'S-1-5-21-836115440-534592245-2745282963-1000', 'user', 'GRIMMY001', '0x56ba3', '2', 'User32 ', 'Negotiate', 'GRIMMY001', '{00000000-0000-0000-0000-000000000000}', '-', '-', '0', '0x334', 'C:\Windows\System32\winlogon.exe', '127.0.0.1', '0'
Security - 9/15/2008 5:00:44 PM: The description for Event ID '4624' in Source 'Microsoft-Windows-Security-Auditing' cannot be found.  The local computer may not have the necessary registry information or message DLL files to display the message, or you may not have permission to access them.  The following information is part of the event:'S-1-5-18', 'GRIMMY001$', 'WORKGROUP', '0x3e7', 'S-1-5-21-836115440-534592245-2745282963-1000', 'user', 'GRIMMY001', '0x56bbc', '2', 'User32 ', 'Negotiate', 'GRIMMY001', '{00000000-0000-0000-0000-000000000000}', '-', '-', '0', '0x334', 'C:\Windows\System32\winlogon.exe', '127.0.0.1', '0'
Security - 9/15/2008 5:00:44 PM: The description for Event ID '4672' in Source 'Microsoft-Windows-Security-Auditing' cannot be found.  The local computer may not have the necessary registry information or message DLL files to display the message, or you may not have permission to access them.  The following information is part of the event:'S-1-5-21-836115440-534592245-2745282963-1000', 'user', 'GRIMMY001', '0x56ba3', 'SeSecurityPrivilege
            SeTakeOwnershipPrivilege
            SeLoadDriverPrivilege
            SeBackupPrivilege
            SeRestorePrivilege
            SeDebugPrivilege
            SeSystemEnvironmentPrivilege
            SeImpersonatePrivilege'
Security - 9/15/2008 5:28:33 PM: The description for Event ID '4648' in Source 'Microsoft-Windows-Security-Auditing' cannot be found.  The local computer may not have the necessary registry information or message DLL files to display the message, or you may not have permission to access them.  The following information is part of the event:'S-1-5-18', 'GRIMMY001$', 'WORKGROUP', '0x3e7', '{00000000-0000-0000-0000-000000000000}', 'SYSTEM', 'NT AUTHORITY', '{00000000-0000-0000-0000-000000000000}', 'localhost', 'localhost', '0x288', 'C:\Windows\System32\services.exe', '-', '-'
Security - 9/15/2008 5:28:33 PM: The description for Event ID '4624' in Source 'Microsoft-Windows-Security-Auditing' cannot be found.  The local computer may not have the necessary registry information or message DLL files to display the message, or you may not have permission to access them.  The following information is part of the event:'S-1-5-18', 'GRIMMY001$', 'WORKGROUP', '0x3e7', 'S-1-5-18', 'SYSTEM', 'NT AUTHORITY', '0x3e7', '5', 'Advapi  ', 'Negotiate', '', '{00000000-0000-0000-0000-000000000000}', '-', '-', '0', '0x288', 'C:\Windows\System32\services.exe', '-', '-'
Security - 9/15/2008 5:28:33 PM: The description for Event ID '4672' in Source 'Microsoft-Windows-Security-Auditing' cannot be found.  The local computer may not have the necessary registry information or message DLL files to display the message, or you may not have permission to access them.  The following information is part of the event:'S-1-5-18', 'SYSTEM', 'NT AUTHORITY', '0x3e7', 'SeAssignPrimaryTokenPrivilege
            SeTcbPrivilege
            SeSecurityPrivilege
            SeBackupPrivilege
            SeRestorePrivilege
            SeDebugPrivilege
            SeAuditPrivilege
Security - 9/15/2008 5:29:00 PM: The description for Event ID '4648' in Source 'Microsoft-Windows-Security-Auditing' cannot be found.  The local computer may not have the necessary registry information or message DLL files to display the message, or you may not have permission to access them.  The following information is part of the event:'S-1-5-18', 'GRIMMY001$', 'WORKGROUP', '0x3e7', '{00000000-0000-0000-0000-000000000000}', 'SYSTEM', 'NT AUTHORITY', '{00000000-0000-0000-0000-000000000000}', 'localhost', 'localhost', '0x288', 'C:\Windows\System32\services.exe', '-', '-'
Security - 9/15/2008 5:29:00 PM: The description for Event ID '4624' in Source 'Microsoft-Windows-Security-Auditing' cannot be found.  The local computer may not have the necessary registry information or message DLL files to display the message, or you may not have permission to access them.  The following information is part of the event:'S-1-5-18', 'GRIMMY001$', 'WORKGROUP', '0x3e7', 'S-1-5-18', 'SYSTEM', 'NT AUTHORITY', '0x3e7', '5', 'Advapi  ', 'Negotiate', '', '{00000000-0000-0000-0000-000000000000}', '-', '-', '0', '0x288', 'C:\Windows\System32\services.exe', '-', '-'
Security - 9/15/2008 5:29:00 PM: The description for Event ID '4672' in Source 'Microsoft-Windows-Security-Auditing' cannot be found.  The local computer may not have the necessary registry information or message DLL files to display the message, or you may not have permission to access them.  The following information is part of the event:'S-1-5-18', 'SYSTEM', 'NT AUTHORITY', '0x3e7', 'SeAssignPrimaryTokenPrivilege
            SeTcbPrivilege
            SeSecurityPrivilege
            SeBackupPrivilege
            SeRestorePrivilege
            SeDebugPrivilege
            SeAuditPrivilege
System - 9/15/2008 5:05:25 PM: The description for Event ID '1073748860' in Source 'Service Control Manager' cannot be found.  The local computer may not have the necessary registry information or message DLL files to display the message, or you may not have permission to access them.  The following information is part of the event:'FSGKHS', 'stopped'
System - 9/15/2008 5:24:19 PM: The description for Event ID '1073748860' in Source 'Service Control Manager' cannot be found.  The local computer may not have the necessary registry information or message DLL files to display the message, or you may not have permission to access them.  The following information is part of the event:'Protected Storage', 'running'
System - 9/15/2008 5:24:24 PM: The description for Event ID '1073748860' in Source 'Service Control Manager' cannot be found.  The local computer may not have the necessary registry information or message DLL files to display the message, or you may not have permission to access them.  The following information is part of the event:'Telephony', 'running'
System - 9/15/2008 5:24:24 PM: The description for Event ID '1073748860' in Source 'Service Control Manager' cannot be found.  The local computer may not have the necessary registry information or message DLL files to display the message, or you may not have permission to access them.  The following information is part of the event:'Secure Socket Tunneling Protocol Service', 'running'
System - 9/15/2008 5:24:24 PM: The description for Event ID '1073748860' in Source 'Service Control Manager' cannot be found.  The local computer may not have the necessary registry information or message DLL files to display the message, or you may not have permission to access them.  The following information is part of the event:'Remote Access Connection Manager', 'running'
System - 9/15/2008 5:28:10 PM: The description for Event ID '1073748860' in Source 'Service Control Manager' cannot be found.  The local computer may not have the necessary registry information or message DLL files to display the message, or you may not have permission to access them.  The following information is part of the event:'Application Information', 'running'
System - 9/15/2008 5:28:33 PM: The description for Event ID '-1073731795' in Source 'DCOM' cannot be found.  The local computer may not have the necessary registry information or message DLL files to display the message, or you may not have permission to access them.  The following information is part of the event:'MSIServer', '', '{000C101C-0000-0000-C000-000000000046}'
System - 9/15/2008 5:28:33 PM: The description for Event ID '1073748860' in Source 'Service Control Manager' cannot be found.  The local computer may not have the necessary registry information or message DLL files to display the message, or you may not have permission to access them.  The following information is part of the event:'Windows Installer', 'running'
System - 9/15/2008 5:29:00 PM: The description for Event ID '-1073731795' in Source 'DCOM' cannot be found.  The local computer may not have the necessary registry information or message DLL files to display the message, or you may not have permission to access them.  The following information is part of the event:'TrustedInstaller', '', '{752073A1-23F2-4396-85F0-8FDB879ED0ED}'
System - 9/15/2008 5:29:00 PM: The description for Event ID '1073748860' in Source 'Service Control Manager' cannot be found.  The local computer may not have the necessary registry information or message DLL files to display the message, or you may not have permission to access them.  The following information is part of the event:'Windows Modules Installer', 'running'
**************** Windows Experience Index *******************
CPU Score: 5.6
Disk Score: 5.8
Graphics Score: 5
Direct 3D Score: 5.3
Memory Score: 5.9
WEI Score: 5
************************* Users *****************************
Name: Abigail Domain: GRIMMY001
FullName: Abigail Description:
Disabled: False
Status: OK
LocalAccount: True
PasswordChangeable: True
PasswordExpires: False
PasswordRequired: True
Name: Administrator Domain: GRIMMY001
FullName:  Description: Built-in account for administering the computer/domain
Disabled: True
Status: Degraded
LocalAccount: True
Name: Aliyah Domain: GRIMMY001
FullName: Aliyah Description:
Disabled: False
Status: OK
LocalAccount: True
Name: Guest Domain: GRIMMY001
FullName:  Description: Built-in account for guest access to the computer/domain
Disabled: True
Status: Degraded
LocalAccount: True
PasswordChangeable: False
PasswordRequired: False
Name: user Domain: GRIMMY001
FullName: Grimmy Description:
Disabled: False
Status: OK
LocalAccount: True
************************** Memory ***************************
Manufacturer: None
Model:
Bank Label: Bank2/3
Capacity: 2048 MB
Description: Physical Memory
Tag: Physical Memory 1
Manufacturer: None
Model:
Bank Label: Bank6/7
Capacity: 2048 MB
Tag: Physical Memory 3
************************ Video Card *************************
Brand: NVIDIA
Model: NVIDIA GeForce 8600 GT
Adapter DAC Type: Integrated RAMDAC
Adapter RAM: 512 MB
Current BitsPerPixel: 32
Current Number Of Colors: 4294967296
Current Refresh Rate: 75
Driver Date: 12/12/2007 01:06:00
Driver Version: 7.15.11.6925
MaxRefreshRate: 85
MinRefreshRate: 50
Status: OK
Video Memory Type: 2
Video Mode Description: 1280 x 960 x 4294967296 colors
Video Processor: GeForce 8600 GT
************************** Drives ***************************
Model: MAXTOR S TM3320620AS SCSI Disk Device
Description: Disk drive
InterfaceType: IDE
Partitions: 2
SCSIBus: 0
SCSILogicalUnit: 0
SCSIPort: 4
SCSITargetId: 0
SectorsPerTrack: 63
Status: OK
************************ CD/DVD Rom *************************
Name: HL-DT-ST DVDRAM GSA-H44N ATA Device
Description: CD-ROM Drive
LastErrorCode:
Manufacturer: (Standard CD-ROM drives)
Media Type: DVD Writer
Name: PIONEER DVD-RW  DVR-107D ATA Device
LastErrorCode:
************************* IDE/SATA **************************
Manufacturer: (Standard IDE ATA/ATAPI controllers)
Name: Standard Dual Channel PCI IDE Controller
Last Error Code:
Status: OK
Last Error Code:
Status: OK
Last Error Code:
Status: OK
Manufacturer: NVIDIA Corporation
Name: NVIDIA nForce Serial ATA Controller
Last Error Code:
Status: OK
Last Error Code:
Status: OK
Last Error Code:
Status: OK
Last Error Code:
Status: OK
Last Error Code:
Status: OK
Last Error Code:
Status: OK
************************** Network **************************
Windows IP Configuration
   Host Name . . . . . . . . . . . . : Grimmy001
   Primary Dns Suffix  . . . . . . . :
   Node Type . . . . . . . . . . . . : Hybrid
   IP Routing Enabled. . . . . . . . : No
   WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection 4:
   Connection-specific DNS Suffix  . :
   Description . . . . . . . . . . . : USB Cable Modem Network Device
   Physical Address. . . . . . . . . : 00-1B-2F-85-27-17
   DHCP Enabled. . . . . . . . . . . : Yes
   Autoconfiguration Enabled . . . . : Yes
   Link-local IPv6 Address . . . . . : fe80::79a6:86f2:cd81:8be7%14(Preferred)
   IPv4 Address. . . . . . . . . . . : 192.168.0.2(Preferred)
   Subnet Mask . . . . . . . . . . . : 255.255.255.0
   Lease Obtained. . . . . . . . . . : Monday, September 15, 2008 4:59:22 PM
   Lease Expires . . . . . . . . . . : Monday, September 15, 2008 5:59:22 PM
   Default Gateway . . . . . . . . . : 192.168.0.1
   DHCP Server . . . . . . . . . . . : 192.168.0.1
   DNS Servers . . . . . . . . . . . : 198.142.0.51
                                       203.2.75.132
   NetBIOS over Tcpip. . . . . . . . : Enabled
Ethernet adapter Local Area Connection 2:
   Media State . . . . . . . . . . . : Media disconnected
   Description . . . . . . . . . . . : NVIDIA nForce Networking Controller #2
   Physical Address. . . . . . . . . : 00-1D-60-0D-BB-5F
Ethernet adapter Local Area Connection:
   Physical Address. . . . . . . . . : 00-1D-60-0D-B7-A3
Tunnel adapter Local Area Connection* 6:
   Description . . . . . . . . . . . : isatap.{06F0EF1C-5196-4071-80FA-0029747429D4}
   Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
   DHCP Enabled. . . . . . . . . . . : No
Tunnel adapter Local Area Connection* 7:
   Description . . . . . . . . . . . : isatap.{3DB234B0-AE52-4C4B-8BBC-3E84590437D6}
Tunnel adapter Local Area Connection* 9:
   Description . . . . . . . . . . . : isatap.{0F136459-B590-4C23-99F9-DDD9C9E969F1}
Tunnel adapter Local Area Connection* 11:
   Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
   Physical Address. . . . . . . . . : 02-00-54-55-4E-01
   IPv6 Address. . . . . . . . . . . : 2001:0:cf2e:308c:103f:b1c:8594:3d6b(Preferred)
   Link-local IPv6 Address . . . . . : fe80::103f:b1c:8594:3d6b%12(Preferred)
   Default Gateway . . . . . . . . . : ::
   NetBIOS over Tcpip. . . . . . . . : Disabled
********************* Systerm Restore ***********************
Description: Scheduled Checkpoint
Creation Time: 09/10/2008 02:25:51
SequenceNumber: 485
Creation Time: 09/11/2008 06:10:53
SequenceNumber: 486
Description: Windows Update
Creation Time: 09/11/2008 10:00:10
SequenceNumber: 487
Creation Time: 09/12/2008 04:42:12
SequenceNumber: 488
Creation Time: 09/12/2008 14:56:06
SequenceNumber: 489
Creation Time: 09/12/2008 20:39:29
SequenceNumber: 490
Creation Time: 09/13/2008 09:00:22
SequenceNumber: 491
Creation Time: 09/13/2008 10:00:11
SequenceNumber: 492
Creation Time: 09/14/2008 07:00:02
SequenceNumber: 493
Creation Time: 09/14/2008 20:00:14
SequenceNumber: 494
Creation Time: 09/15/2008 15:29:39
SequenceNumber: 495
******************** Running Processes **********************
Name: System Idle Process
Name: VistaForums SysInfo.exe
    AMD AM2 x2 6000+
    ASUS M2N SLI Deluxe
    Asus 8600 GT SLI
Since the last time it has come up a number of times again while my daughter was using it so i am stumped as to what this is and how to fix it. Thanks for the help by the way. :) Appreciate any that i can get at the moment lol.
    AMD AM2 x2 6000+
    ASUS M2N SLI Deluxe
    Asus 8600 GT SLI
Your logs look ok.
type "memory diagnostic tool" into your start seach box an run the diagnostic to check your memory.
    Windows 11 Workstation
    Ryzen 9 5950X
    Creative
    1500W ThermalTake Toughpower
    ThermalTake Level 10 GT
    Enermax Liqtech 240
    Logitech Performance MX
    Surface Ergonomic.
    350 Mb/s
    windows 10
    Surface Pro 3
    12" Multi Touch
    2160 x 144
    128GB
    yes
    350 Mb/s
Well back again and i have run that memory diagnostic tool and it says no errors detected so i am back to square one and i still don't know what causes it. Any other suggestions? is there a file that i can bring up and post that has those errors that come up when i get the BSOD and it does its minidump?
    AMD AM2 x2 6000+
    ASUS M2N SLI Deluxe
    Asus 8600 GT SLI
NEVER EVER EVER USE THE ASUS UPDATER AS IT WILL DESTROY YOUR BIOS (sorry about the shouting :shock: )
The Asus windows updater has something like a 3% success rate and it should be taken off their website. Best to use the EZFlash within the bios or do it via dos prompt. But always outside of the O/S environment with no Overclocked settings ( set bios to default first ).
    system1 (system2)
    q9650 3ghz (i7 920)
    Asus p5q deluxe (p6t deluxe)
    16gb ddr2 (12gb ddr3)
    Nvidia 8800GTS 640mb (285gtx 1gb)
    on board
    Eizo CG301w, Dell 2407
    2560 x 1600 + 1920 x1200
    Raptor 74gb, Raptor 150gb, 500gb x2, 320gb, 750gb (raptor 150gb, 2x 500gb)
    ocz 600w (ocz750w)
    coolermaster stacker (coolermaster 690)
    many fans
    intellimouse
    apple slim aluminum jobbie
    2mb
    Wacom A3 tablet, Epson 3800
