Hi
I have a Hp Laptop with Vista Home Premium 32 bit. I recently downloaded the update of flash player which keeps freezing up and crashing when I try to stream video's, Then when I use Firefox I get a small window that pops up that says" "I need a plugin". then my FF crashes, and also if I use my Incredimail it crashes as well. So not sure what is really going on.
Do you have any ideas?
Thanks
Thanks
- HP
- 2gig
