New computer with Visat 64 installed. Recently installed Office 07 and this morning discovered a problem I cannot figure out. With Explorer open, I click on File-Send-Link By Email, email does not open and I cannot exit out of Explorer. When you click on the "x" to close Explorer all the computer does is ding. What is going on, this is about to drive me nuts?
UPDATE: Just got off the phone with Dell Tech Spt, they remotely accessed my system and this is what they said: That there was a conflict with the 64 bit and Outlook 07. With Outlook 07 open and Explorer open, the system will allow you to go to Explorer and File-Send-Link By Email, works fine in this case. If Outlook is closed though, Explorer will not open it. Dell said it appears to be a 64 bit conflict.
Has anyone heard of /experienced this? Was the Dell rep correct?
