Small home wireless LAN, Netgear WGR614v4 router, Using WPA, two XP machines, one Vista (home Basic
Stage 1) all working ok for many hours, except when
2) Vista machine goes to sleep mode. On wakeup, no connection. Network SSID is visible, good signal, but repeated attempts to connect fail.
3) Other computers connect to router, and internet fine. They can also standby/poweroff and restart fine. Still connected.
4) Reboot Vista computer, no help. Network settings look normal, just no connection to wireless router. Incredibly irritating Vista diagnostic tool suggests I connect to a another network, or recycle the router. (If the router was close enough to be easily recycled, I would just plug in an ethernet cable. But it is not, and I am tired of unnecessary trips to the basement.)
5) Power cycle router, and everything fine again.
Does not happen with every sleep cycle. No clue what makes it fail sometimes and not others.
Any suggestions? This happens about every other day, so of course, it will not fail when I want it to, but if anyone has an idea, I will get ready for the next breakage.
